SOURCE: ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
SOURCE: Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
SOURCE: ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Testimonial: "Problem Solved! Caps were spilling out all over the place. Sorry it took so long to reply >.<"
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
SOURCE: viewsonic vx2835wm monitor, in DVI
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
