Haier 5.3 cu. ft. Chest Freezer HNCM053E Logo
Posted on Sep 12, 2011
Have a Haier Chest Freezer Model #BD120G. The green power light is of. However, the freezer appeasr to be operating properly. Do I need anew light?
America Refrigeration
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 40 Answers
  • Posted on Nov 15, 2013
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
40
Questions
0
Helped
12553
Points
45
Don't worry about it, the light burn with the time, but it don't harm the compressor at all.
5 Related Answers
Anonymous
  • 136 Answers
  • Posted on Mar 13, 2008
SOURCE: Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Anonymous
  • 124 Answers
  • Posted on Nov 21, 2008
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Anonymous
  • 410 Answers
  • Posted on Jul 04, 2009
SOURCE: Where can we get a manual for the HCM073PA Haier
on your model freezer one of the switches actually turns the unit off and on and the other turns the alarm off and on. unfortunatley i'm not sure which one does which. here is the part numer for the manual RF-9999-208 and it can be ordered thru sears.com for 3.50 alternatively you could check haier's web site to see if they have a downloadable version. thanks Peyton
Anonymous
  • 585 Answers
  • Posted on Jul 07, 2009
SOURCE: I have a GE chest freezer and the exterior green
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
victorwod
Victor Nwachukwu
  • 157 Answers
  • Posted on Feb 20, 2010
SOURCE: my chest freezer is making the noise to no its on
that green light is the mains light and it will stop later .
Green light on chest freezer flickering?
this just means the light is burning out (loosing its filament) it does not effect the operation of the freezer, it just is an indicator that you have power at the unit.
Aug 30, 2014 • Freezers
1helpful
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
I have Haier 5 cubic foot chest freezer, model # HCM050LA, that cools well with the green light on. When it is running it makes a very faint high pitched sound that seems to be coming from the top right...
Yes it does. It will have to be blowing inside so look in there. You will have to take the cover off.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
3helpful
2answers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
