SOURCE: PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
SOURCE: copier
I'm way late..... but the used toner is located under the transport belt assembly. Remove belt assy., and vacuum out waste toner -clean sensor on bottom of unit.
SOURCE: ricoh 4420L fax machine
Go to www.ricoh-usa.com
Click "Downloads"
Click "Download Ricoh manuals"
Under "Facsimile", click the drop down
box, highlight 3310LE, click "Go".
Download both manuals.
In the Advanced manual, page 84, shows the
settings to turn off or on memory or immediate
transmission result reports.
SOURCE: Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
