Includes Mosquito net, raincover, mattress and blanket
Adaptable to fit Quinny Buzz or Quinny Speedi stroller
I hope this helped answer your question. I would also see if the baby is fitting tightly in the bassinet, and if so I would remover your child and purchase something else. This is a great item.
The quinny speedi should come with the adaptors to fit the bassinet (the quinny dreami) Once you remove the pushchair seat unit by undoing the clips and undoing the velcro the fastenings you then need to remove the 2covers or bumper bar(depends on model) above the quinny logo on the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. The carrycot is then place onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood.
HTH
Hi
this part comes as standard on the 2009 models and above. They can be ordered separately for older models and your local Quinny retailer should be able to order them for you. Alternatively google speedi bumper bar and you should get results for online stockists
The rain cover should come provided with your speedi dreami carrycot. These are quite tight fitting to begin with. I found it easiest to start with the hood up and put the rain cover on over this part first. Then it is a matter of stretching the cover down over the base of the carrycot. It will loosen slightly with use and become easier to fit.
