Question about HP PSC 1610 All-In-One InkJet Printer
My HP PSC 1610 is adding about 1/2 inch to the top of all documents printed. I have cleaned the encoder strip, not a disc, and I have checked all the page settings in every document I have tried to print. I have tried to clean everything readily available to me but I am not sure what else controls the paper input other then the encoder strip. All the feeds seem to be working fine and the paper goes in ok then the printer moves it forward about1/4 to 1/2 inch before it starts printing.
    Sergeant:
    Champion:
  • 289 Answers
Pls try uninstalling the microsoft office, then reinstall it back the try again to print
Posted on Nov 06, 2011
  • tbalaski Nov 07, 2011
    I have found out that Office documents from older versions of Office (2003) are the problem. When I convert them to Office 2010 documents they print okay. Thanks.
6ya staff
SOURCE:
HP PSC 1610 printer is adding a half inch on the top of all documents
Check the page settings in system, clean paper leading edge sensor,disc encoder..
Sep 12, 2011 | HP PSC 1610 All-In-One InkJet Printer
The printer will print a document but does not put it all on one page. Sometimes it prints part of the document, then sends out a blank page, then prints the remainder of the document on a third page. We...
1. check paper length..... Select proper lengths
2. check printing leading edge, weather its matching to the selected scale?...Clean paper sensor & disc encoder
3. check printed caractors, is there any abnormal caractors?....clean Disc encoder & sensor
3. remove back door clean the paper sensor and check sensor flag
4, clean disc encoder & sensor...
goodluck..
Sep 05, 2011 | HP Deskjet Printer
Printer cuts off print at top of page in spite of over 1" margin and every 3rd or fourth line of print in document is very weak (not much ink)
Hello
Well are you using the external ink-system? even if you are not the disk encoder and the encoder strip needs to be cleaned. Encoder Strip is the plastic strip connecting from left to right inside the printer near the belt. In the same type of plastic there is an Disk encoder on the left side of the printer you can find it if you open the printer only.
Jul 23, 2011 | HP OfficeJet Pro k550 Printer
I upgraded my Mac mini to Snow Leopard OSX 10.6.2. Reloaded the printer software but the printer wont print. THe printer is connected via USB. When I send a document it shows error on the printer queue....
HP PSC 1610 All-In-One InkJet Printer Printer HP PSC 1610 always printed till I... Answer I think I have a similar problem:HP PSC 1610 always printed till I installed Mac OS X 10.6. also does not digitalize since I downloaded: HP_Installer_PSC1600_v9.7 An error apears about a missing extention ? ? ? ? Carlos Moniz
Feb 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
About 1/3 of the way over, one vertical line of text in my resume seems to be bolded going down through the entire document. The rest looks fine, any ideas?
Sounds like a smudge on the encoder strip. The clear plastic behind the carriage assembly. if you hold the paper at the paper path the encoder strip will have the smudge in the same area as on the paper. you can clean it with a damp Q-tip...gently though
Jul 02, 2009 | HP PSC 1210 All-In-One InkJet Printer
My hp psc 1610 printer will not print
1. Click the Start icon, click Control Panel, click Printers and faxes folder.
2. Right Click on the printer icon and Select Properties.
3. In Ports tab of the properties window, check the box beside "Enable bi-directional support".
4. Click OK to confirm the changes.
Feb 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Can i install the ha psc 1610 all in one printer without a disc
I have the same printer. It's awful. The software's worse.
But you can download it from http://www.hp.com.
Support and drivers
Download drivers and software (radio button at the top)
Type in PSC 1610 in the text box
Pick your operating system
And .. go. The Vista drivers are ~160mb. Ouch.
Dec 20, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
HP PSC 1610 All-In-One InkJet Printer Logo
51 people viewed this question
Ekse
Thomas F. Schneider
