SOURCE: LG WM2487H*M Drum light stays lit after each load is completed
I checked with a certified technician on this problem. Unfortunately the repair cost me $200. The main circuit board needed to be replaced, and the unit works as advertised now. It's actually easy to access the circuit board in the left rear of the washer, but it was a challenge to remove the 16 connections! If you aren't intimidated by this kind of repair, take your time and all will go well.
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
