Tanita Step PD 724 Pedometer Logo
Posted on Sep 13, 2011
I inadvertently turned on some kind of alarm and I can't turn it off. How do I reset my Tanita pedometer.
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
3329
Points
62
TAKE THE BATTERYS OUT
1helpful
I walk a lot so have bought a Tanita pedometer PD-724.Cannot seem to set stride length Help, Iam 78
That's okay Dorothy ...
I won't hold your youth & in-experience against you.
(Walk a lot: Good girl!)
Tried (really) looking it up... (below) 3 axes pedometer
http://www.tanita.com/es/pd724gl/
Seems 2 B a serious brain teaser. .. but if you have the numbers... weight and stride length.. you just advance to those settings with your mode control.
The only ISSUE I can imagine: you could have your stride length... in CENTIMETERS (METRIC)... So if your stride is
30 inches... that equals 76.2 CM (centimeters).
Aaaand...
if you underestimate your stride a little... It will make you feel like you accomplished more... (and who's to tell).
You go girl...
Comment me back if that didn't do it for you.
If you need to Phone them (Tanita) ...
Tanita Corporation of America, Inc.
Customer Service / Service Center
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005, USA
Phone: (847) 640-9241
Fax: (847) 640-7978
eMail: [email protected]
http://www.tanita.com/en/contact-customer-service/ Contact Customer Service
Personal Scales Manual Downloads
Instructions required for BBC Big Challenge pedometer
http://www.tanita.asia/uploads/media/PD_639.pdf
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
My Tanita PD-724 keeps resetting to zero during the day and also resetting the clock at random times
The same thing has been happening for me. I don't have a tried and tested solution, but I'm suspecting that it's when I keep the pedometer in the same pocket as my mobile phone. I'll make sure I don't do that and report back if it still resets.
8helpful
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
I have a maxi aid Talking pedometer and can't figure out how to turn the alarm off
You can cycle threw all the Alarm sounds buy pressing the "UP and DOWN" buttons simultaneously until you hear the "Alarm off" voice, also you will see the little "Bell display" above and between the hours and minutes go away.
2helpful
My Tanita 3 Axes Pedometer Pd724 got wet n the alarm started to go off . I had to take the battery out to stop and every time I put the battery In the alarm starts again and I cannot do anything else help...
Hi honeyrauniar
The alarm goes off when the pedometer is pulled away from the pin (at one end) to which the strap is attached. Just push the pin back in and it stops the alarm!
RM
4helpful
2answers
Hi I've got a Tanita Pedometer - PD724, and have lost the instructions. Have had to put in a new battery, but can't clear the dsplay or re set it . Can anyone help? Clare
I can not find the instructions, (there are sites that warn not to lose it)
So lets go with what I think I know.
Press and hold the Mode button until your display starts flashing.
Once it does, use your other two buttons for varying the display amounts.
At least, that is what i would do.
Also, my wife get sooooo mad at me, but I have every instruction manual for everything i bought somewhere in the house....
good luck and don't forget to vote!!!
76helpful
5answers
Voicezone talking pedometer instructions, turn off alarm
Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
Top Tanita Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tanita Exercise and Fitnes Expert? Answer questions, earn points and help others
