Use the new mac driver for any black and white machine it will work. the new driver i think is 3.0.
www.copystar.com
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: Won't print documents from computer! PLEASE HELP! ASAP!
You cannot use an IP number for more then one device. It is an unique identification number. On the PORT section uner the Windows driver, change the last three digits for the Copystar machine, do not change the other ones (keep in mind that it should be unique!). Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
SOURCE: kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
SOURCE: Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
