Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has itwhere do I insert my microSD memory card or does - brymz_7.jpg data-src="/uploads/images/brymz_7.jpg" alt="brymz_7.jpg" class="h_mi" />
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Hi there.
It depends on the computer you have if it includes a memory card reader. Most memory card readers on laptops only read regular sized SD cards so you would need an adapter like the large thing in your image to put it in the laptop. If your computer does not have one you will need to get a USB memory card reader from your local computer shop. One that looks like this:
http://aluratek.com/microsd-minisd-usb2-0-multi-media-card-reader
There are many of these on the market. Just make sure you get one that can read MicroSD cards if you don't have that adapter that is in the picture.
SOURCE: Memory card is too small.
you need to get an adapter from micosd to sd or connect your phone via cable or bluetooth
SOURCE: how to solve the problem " please insert the disk into drive" of memory card
ok how did format get done? if not on computer then formatting needs to be done with card in computer and do a thorough format NOT quick format
To format a microSD memory card follow the steps below:
