F-05 are draining problems. What you need
to do is just double check theres nothing stuck in the sump hose or the
drain pump. Then check the pump impeller turns ok. It should ping round
in stages. If its stiff to turn then the pump is faulty and will need
to be replaced.
Then retry machine and see how it goes from there. If
its still the same then you need to check to see if the impeller is
turning when set to spin. If it isnt then you need to see if you have
240v going to it. If you do then the pump will be the problem and will
need to be replaced.
Hope helps.
