I have the same probleme and i want a solution plz
HL-DT-ST DVDRAM GSA-T20N ATA DEVICE WILL NOT READ ANY DISCS AND HAS ERROR CODE 19
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39.
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
My driver wont work because of the HL-DT-ST DVDRAM GSA- T20N ATA Device.
I have same problem.
I HAVE SAME PROBLEM :(
Does anyone know any solution?
I get the same message. How can I fix this?
[Start] [Run] [Regedit] Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318} Value Data: [Delete All Value Data from UpperFilters and LowerFilters] Note: Do not delete the Key or the Multi-String Values. Delete only the data values. Exit Registry and Reboot
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 10
HL-DT-ST DVDRAM GSA-T20N ATA Device problem
Device driver not valid or not loaded
i have the same problem
code 39...
how da hell you fix it because when ever i upgrade my computer then it doesnt even work after dat
I HAVE THE SAME PROBLEM OF CODE 39. PLEASE SOMEONE HELP ME. I AM A NOVICE IN THIS KIND OF PROBLEM. THANKS.
i have the same problem! its annoying for a new computer!!
I have the same problem code 39 - updated driver but still not working
i have error 39 and dont read discs
The dvd /cd will not run cd or dvd
Same problem - new laptop
i have an error code 39. and it says windows cannot load due to driver missing or is corrupted
I have the same problem. Stopped playing discs, error code 39. I uninstalled it, and my comp tried to automatically install driver software, but it said it couldn't. I've tried drive checker, it still doesn't work. How do I solve this? Anyone?
Same problem. What do I do?
Same problem Code 19. Thanks!
I have same problem. DVD doesn't work when check found code 39. Plz help!!!
I have a problem with this too, error code 39, but can't seem to see the solution on this page
My DVD driver isnt working at all. It doesnt show on my computer.
I hve problume too
i have the sama problem, HL-DT-ST DVD RAM GSA-T20N ATA Device with the error classed as code 39
my HL DT ST DVDRAM GSA T20N ATA Device
dosen't work and there is no ikon for it
Windows tries to install driver on startup but fails every time
