For decent signal to noise ratio your channel faders should be about 75% up. You should set the trims when punching down the PFL button for each channel so that peaks go up the meter to about 80% of max. Your master levels shoulld be from 50 to 80% up. You should be using BALANCED cables (TRS or XLR) everywhere. Your equipment should ALL be powered from a single receptacle or power conditioning module, even if it means running extension cords. Many people try to run unbalnced cables from this to their amps... it doesn't work and noise results. You didn't give us much info on your system so that we could analyze further
