Dear Sir:
I will help you inmediately:
Check the circuit breaker to see if it hastripped. If the reset/off circuit breaker has tripped, wait 5 minutes andreset.
If the power cord is properly plugged in, unplugit and wait 5 minutes before plugging it back into the surge protector.
Remove and reinsert the console key.
4)Remove the key from the console and UNPLUG THE
POWER CORD.
5) Next, remove the screws from the hood
and carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley .
6)Turn the Pulley until the Magnet is aligned with the Reed
Switch. Make sure that the gap between the Magnet
and the Reed Switch is about 1/8". If necessary, loosen
the indicated Screw , move the Reed Switch slightly,
and then retighten the Screw.
Re-attach the hood and run
the treadmill for a few minutes to check for a correct speed
reading.
Thank you in advance,blessing, if you need some additional assistance please reach me. sincerely.
E.CUADRA
Managua, Nicaragua. C,A
