Thank you for posting your question on fixya. I will be happy to help you with this problem. Can you please give us some more information so I can better answer your questions.
Will like to know the model of the remote control before we can be able to help you..
Thanks..
Just asking,,do you have the manual of your remote AKB72914003.?
You might need to reset the remote. Remove batteries from remote control. Press and hold any button for one minute. This will drain power out of the remote and reset it. Universal remotes will have to be reprogrammed.
Hi, thanks for replying,i understood what you said earlier. just that i forgot how to change it to numbers..so please bear with me,and tell me the Model of your TV set so i can get the manual for you to know how to change from alphabet to number .sorry about that..And thanks for your patience..
How to change from alphabet to numbers can be found on the manual of the remote..
Hi, sorry to inconvenience you.Everything you would love to know about the remote control functions is on the manual from pages 63...
Use the link below to view manual..
http://www.manualowl.com/m/LG/55LE5400/M...
Hope it helped.
Thanks for your patience and thanks for using fixya..Have fun..
Model AKB73715601
AKB73715608
Can’t change numbers to letters
Regards,
Tony
OK.
Yes, There is a button called the "ratio" button right between the volume and channel adjustments that does toggle. Sorry about the confusion.
Tony
You do the same Adler2341
The only numbers I see on the remote are: AKB72914003. Is this what you wanted?
Thank you so much.
I don't think I've explained my problem very well. For example, the number "2" also controls the letters "ABC"; the number "3" also controls the letters "DEF" and so on. I am trying to enter a network code consisting of both numbers AND letters. The letters I can enter by hitting the corresponding key sufficient times. EG, to enter "B" I hit the number "2" key two times, etc. Now, I need to enter numbers. For example, how would I enter "coolken2341"? I can get the "coolken" part, now I need to switch to numbers for the rest.
Thank you for your patience. It appears to be a LG 55LE5400
Bingo! Everything is working and I am connected to Netflix. I couldn't be more pleased. I would like to give you a tip. Is that possible?
Nope. Mine doesn't work that way. However, I was directed to the solution which is a toggle button on the remote. Thanks anyway. I do appreciate it.
Very helpful and I am quite satisfied.
Thanx, Tony. Stay Well.
