Most all dishwashers are controlled by the wall switch close to the sink. This switch is often shut off accidentally because it looks like a light switch. Be sure this switch stays on.
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again. Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
F4 Meat probe shorted 1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C], 37kω at 90° F [32.2° C]). 2. If resistance is not valid replace probe. 3. Insert probe and check for a firm connection between probe and jack (in oven cavity). 4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
replace the left & right hinges ( if stainless door they have stronger hinges for this.. this is a very comm problem .. in some model you can use shim kit for this problem but replacing hinges is best avenue . mm
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
I have the same problem, any suggestions on what to do?
