My ps3 will automatically shutdown after turning power on. green light turns on briefly, then i get a yellow light, a beep then turns red and blinks. doesn't stay on long enough to eject disc.
PS3 automatically shutdown means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn : DIY PS3 Repair Guide Not only such shut down problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro. http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
With your PS3 turned off, press and hold the Power button on the front
of the PS3 for about 10 seconds (the system will beep as normal as it
starts up but after 7-10 seconds it will beep again). The video
settings should now be reverted. Doing this will also reset any theme
settings. try this? seems to fix alot of issues.
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
