Question about LG 42PX4DR 42 in. Plasma TV
I've got a LG mt-42pz91m plasma tv. I just want to find out if you can use it without a dstv?mnet decoder (just the sabc channals) And if you can where do you plug the antenna in and how do you tune it in.
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 86 Answers
SOURCE: LG 42" Plasma Faltron MT-42PZ91M
Try a power drain and if this doesn't work, it appears the power supply is defective or is not connected to the mainboard. If the connection was poor, simply moving it may have dislodged it and service would be required to reconnect it. Try the power drain first:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
Hope this works for you.
Posted on Oct 15, 2008
kukere
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
taran_2005
taran_2005
  • 10515 Answers
SOURCE: hi please help me to
I am sorry to hear regarding the trouble.
Image problems on Plasma TVs are usually a result of a failure of fault in the screen buffer boards. There are several buffer boards and each controls a section of the screen: either a column so many pixels wide or a row so many pixels wide. When the buffers start to fail, it is common to see lines either from top to bottom, or from side to side or just portions of a line going halfway across.
You are going to have to call in a pro to check this out. There is no way that someone over the internet can correctly diagnose the TV without being there in person and then it would likely take hours of diagnosis to narrow down the bad part.
It's probably your buffer boards.
If you have electronics repair experience and would like to conduct the repair, revert and i would be able to add few more inputs.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 07, 2011
Not able to connect to TV channels being SABC
you need to explain,what is sabc,dstv,what is the tv,we r not mind readers
Jul 29, 2015 | Samsung Televison & Video
How do i connect more then 1 tv to my mnet decoder
You need a signal splitter from the decoder to the TV(s). But there will be a problem with that. Signal degradation. and channels you want to watch with 1 decoder. Your service provider may come a calling.?? You are aloud 4 TVs per house hold as far as I was told. Good luck.
Jun 02, 2013 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Jul 12, 2011 | Televison & Video
HOW DO I CHANGE FROM ANALOG TO DIGITAL ON AN LG LD32 PLASMA TV?
I havDUEL VIEW DSTV and it went on the blink, I kinda fixed TV1 but on the second TV which is LG after I AUTOMATICALLY RESET IT shows only 4 channels sabc 1 2 3 and etv, so now i cant see dstv and i cant find a channel for it, how do i get it back as it was working fine on tv 2?
May 07, 2011 | LG Televison & Video
Lost remote can i still tune the channals
Hi, you can tune the channels of the Plasma TV without Remote Control. However, I suggest that you to purchase a new Remote Control of the same model number of the Plasma TV with any near by Plasma TV dealer.
Apr 07, 2011 | Samsung PS42B430 42 in. Plasma TV
Aug 30, 2008 | LG 42PX4DR 42 in. Plasma TV
LG 42PX4DR 42 in. Plasma TV Logo
54 people viewed this question
Ekse
RONALD CARTER JR
