Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';
Many Samsung Microwaves have a demonstartion mode retailers use to demonstrate the unit. It allows the unit to function but not heat. The demonstration mode can be turned on and off by holding the 0 while pressing the 1 to turn the demontation mode off and on. This happened to my mother's SMH9187W over the range during cleaning. It is where I would check first before troubleshooting electrical components.
SOURCE: Microwave - no heats - vibrating sound
With the
symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection
on the magnetron's terminal.
The diode is a fairly
cheap fix, and the mag will cost more.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
(it may pass the checks and still be bad)
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If it's under magnetron warranty, GE will
send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Testimonial: "Useful for future. Sears already has it. Saved your links! Thanks."
SOURCE: MICROWAVE NOT HEATING
kenmore over the oven does not heat , the exhaust fan stopped working, but the light works, timer works, and turntable still works. What's wrong?
SOURCE: Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
SOURCE: my microwave comes on lights
The most likely cause is a defective magnetron, "heats food" cost to repair will be close to a new microwave oven.
A diode is an electronic component that
readily passes current in one direction only and blocks the flow of
current in the opposing direction. If your microwave's diode has become
defective, your microwave will not heat and you will hear a buzzing
noise. Test the diode to determine if this is the cause of your problem.
Replace it if it is defective.
A capacitor is an electrical device
which stores electricity. A defective capacitor may be why your
microwave is not heating but you are hearing a buzzing or humming noise.
The capacitor will have to be tested to determine if this is the cause
of your problem. A defective capacitor will have to be replaced before
your microwave will work again. Make sure you discharge the capacitor before you test it, though.
A defective magnetron is the third
possible cause of why your microwave is not heating, but you can hear a
buzzing noise. Test your microwave's magnetron. Replace it if it is
defective.
