I started with 1 thin horizontal black line in the middle of my screen a couple of months ago. Every 2 weeks I get another one. I now have 8 thin horizontal black lines randomly spaced. They never go away. (The picture quality and sound are good.) Can you help? Oh yes, my waranty ran out!!!
Thanks
SOURCE: VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display panel is defective and you must replace it
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
SOURCE: thin horizontal black line appeared lower half of
Fixed non moving lines usually means you have a problem in the panel display or t-con. If it is in warranty get it to a factory authorized service center. If not you can try to change the t-con and see if this fixes the problem, if not then it will be the panel it's self and will be cost prohibitive to repair.
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
