LG Studioworks 563N 15" CRT Monitor Logo
Posted on Sep 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG studiowork 563N desktop bottom screen is getting dark but sometimes it works. i set brightness full but still its dark. Please help.
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Sep 15, 2011
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409550
Points
4988
Hi, It could be you need a new V-card. or your monitor is on its way out. My bets are on the monitor. Good luck.
Video and images too dark
You can try this. Open the cover (Unplug the monitor and leave at least for 30 minutes before doing this). See whether dust is there. If there is dust, get a 1" paint brush and gently remove the dust with the brush. Always sweep the dust away from the unit. If black dust is present around certain cables and around the flyback transformer (that black box covered with aluminium plates), use a soft cloth to wipe them (do not wet the cloth). *Make sure you dont turn those rings on the back of the tube while wiping the the dust. After cleaning the dust, replace the cover, connect it to the PC and check. You will have a brighter picture!
PC is not working in 1024*768
Download Belarc Adviser, install it and run the program. This will tell you lots of things about your computer, Under "Display" it will tell you what kind of graphics card you are using.
It will probably be ATI or nVIDIA. Download and install the latest driver for your card. Be careful that you install the correct one.
For example, if it says nVidia, go here for the latest driver.
After you have installed the latest driver for your graphics card, you can change the display settings to work in 1024*768.
You do this by right-clicking on the desktop and clicking Properties. You will find the settings there.
Hope this helps
Chris (ziraffa)
Brightness
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
Plz help
It had something to do with my old crappy computer, not the monitor. i ended up getting a new computer.
1helpful
3answers
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
1helpful
Lg 563n monitor problem
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Width of picture increase
Have you checked your display adapter settings? Check the display settings in control panel. Make sure you are viewing the screen at a decent resolution. 800/600 or larger. Let me know what happens. Good Luck, Tim
Picture squeezed horizontally
we have right click on desktop <properties<settings <apply ok
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
