JVC AV-65WP74 Rear Projection Television Logo
Posted on Sep 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv has started making red ghosts that go 2 the right of the screen, what is this problem?
Sonny Berry
Level 3:
  • JVC Master 8,617 Answers
  • Posted on Sep 15, 2011
Sonny Berry
JVC Master
Level 3:
Answers
8617
Questions
Helped
1722192
Points
23750
Thats a convergence issue which is common for all rear projection models. The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com will usually solve convergence issues. The kit contains both ICs and the associated resistors and the CD with repair instructions.
2answers
My TV looks like it had permanent 3-D. Red Ghost
hello it sound like the convergance ic may be the problem these chips sit behind the tuner board connected to a metal frame called a heat sink they are soldered in. also you will have to check the resistor in front of the chips also check the 2 capacitors at either end it would be best to get a quote from and engineer good luck
regards
shaun
Hitachi 51f500 wide screen hidef monitor,red green ghosting on right and left sides of screen
Ur tv convergence are dead.U know how to do soldering?U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
1helpful
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Ghosting of the image
*Screen Looks 3-D
*Colors wont align
Problem #2
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Red horizontal lines
Misaligned red lines in your TV is due to failure of Convergence Out ICs and requires replacement.
Let me know if you are familiar with TV repair to provide you part number info OR call local TV tech to fix the TV.
Thanks.
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
1helpful
2answers
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
