First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
Remotes: Basic (Television Only)
Turn the Television On.
Press and hold the TV Power button for three seconds until the LED flashes.
Enter the three-digit code using the buttons on the number pad.
Press OK.
Note: The LED will flash three times.
Test functionality with the TV.
Return to Step 2 if the remote is not able to turn the TV On/Off, change the
volume and mute the television.
Power Scan:
Remote: Basic Remote (Television Only)
Press and release the TV Power button.
Press and release the Up or Down Arrow on the remote until the television
turns off.
After the television turns off, press and release the OK button.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
if the remote has a "code" button you can search for the code by using the power button on the remote.make sure the tv is turned on first.now press and hold the "code" button till the light on the remote stays on.now hit the "tv button,the light on the remote should still be on.now keep hittin the power button until the tv turns off (careful not to press the power button again when the tv turns off or you'll lose the code) then hit the enter button ont he remote.hope this helps you out:) good luck
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too. Mcneileric is right! Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up. NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV! Again... TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup. Mcneileric, THANK YOU!!!!
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
