Toshiba Satellite A135-S2266 Notebook Logo
Anonymous Posted on Sep 15, 2011
I am looking for a simple way to recover my bios password for my toshiba laptop
Eric Rotmil
Level 3:
  • Master 587 Answers
  • Posted on Oct 21, 2011
Eric Rotmil
Master
Level 3:
Answers
587
Questions
0
Helped
175507
Points
1898
Depends on the model, older toshibas you need a jumper plug.
newer ones may need the motherboard reset by toshiba for a fee.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Reset bios Toshiba Satellite C655-sp600l
Password on Hard Drive: you bricked the computer.
Password on Bios: you need to remove the battery (motherboard battery) for 30 seconds and place it again.
Password of Windows: You need to get a software tool designed to recover or reset/delete your Windows password
tip
How to Reset a BIOS Password.
Desktop Machines.
In desktop machines its very simple.
Just remove the BIOS Battery from the motherboard and place it back after 1mint.
Laptop Machines.
It is some what difficult in laptop machines. Because it is not an eassy job to remove BIOS battery from the mother board. So i'm just explaining some most commen methods.
1. Using a Backdoor BIOS Password
The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
2. Resetting the BIOS Password using Software :
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
  • ACER/IBM BIOS
  • AMI BIOS
  • AMI WinBIOS 2.5
  • Award 4.5x/4.6x/6.0
  • Compaq (1992)
  • Compaq (New version)
  • IBM (PS/2, Activa, Thinkpad)
  • Packard Bell
  • Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
  • Phoenix 4 release 6 (User)
  • Gateway Solo - Phoenix 4.0 release 6
  • Toshiba
  • Zenith AMI
3. Resetting the BIOS Password using Hardware :
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
4. Vendor Specific Solutions for Resetting the BIOS Password :
Resetting a Dell BIOS Password For information on how to recover a Dell BIOS password, please refer to How do I reset Dell BIOS password?
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Resetting an IBM ThinkPad BIOS Password For information on how to recover an IBM Thinkpad BIOS password, please refer to How do I reset an IBM ThinkPad BIOS password?
Resetting an IBM Aptiva BIOS Password Some IBM Aptiva's can be convinced to bypass the startup BIOS password if you press both mouse buttons repeatedly while booting the system.
Resetting an Acer BIOS Password For information on how to recover an Acer BIOS password, please refer to How do I reset an Acer BIOS password?
Thanks & Regards
Current009
on Jun 01, 2010 • Computers & Internet
4answers
Toshiba Satalite M35 x, trying to clear bios password, i never set it! Plus the keys are locked, password field will not accept anything
I copied this info from a website since it needs a very particular solution. The only time I had to use it, it worked.
Go to setup (if it lets you) and check the BIOS brand and version.
(If you cant do anything due to the password, then you need some hardware to do that). I hope this helps
Resetting the BIOS Password using Software Every system must store the BIOS password information somewhere. If you are able to access the machine after it has been booted successfully, you may be able to view the BIOS password. You must know the memory address where the BIOS password is stored, and the format in which the BIOS password is stored. Or, you must have a program that knows these things.
You can write your own program to read the BIOS password from the CMOS memory on a PC by writing the address of the byte of CMOS memory that you wish to read in port 0x370, and then reading the contents of port 0x371.
  • ACER/IBM BIOS
  • AMI BIOS
  • AMI WinBIOS 2.5
  • Compaq (1992)
  • Packard Bell
  • Toshiba
  • Zenith AMI
3answers
I have just purchased a shop soiled Toshiba L300D and the bios password has been changed and nobody knows what it is. How do I recover/remove it?
The BIOS password maybe able to be removed provided this laptop had a LPT printer port.
For details of a BIOS password dongle, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4350719-remove_toshiba_bios_password
I bought a Toshiba Satellite L505D-S6952 at A swap meet.They didnt tell me the Password -now I cant find them and I cant use my laptop because I cant bypass the password. please can you help me????
Sure are you looking for the bios password or the OS password?
If your looking for the OS password you can use an program that is advailble on line to recover the password, this will cost you money to get.
I would say to buy the OS cd and reload the system..
http://support.toshiba.ca/support/?lg=en&from=65
You can order replacement cd's from them, or just go buy an OS cd from your computer shop.
1helpful
Laptop wont past bios..needs a password
if it is a bios password than you can go to this site for tips on getting around that password.
http://www.tech-faq.com/reset-bios-password.shtml
if it is a password for windows than you need this software reset the password, it can also recover it.
http://www.spotmau.com/products/package/password_genius.html?gclid=CJCh7v-4gpkCFRMUagodhTwImA
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
2helpful
2answers
Bios password forgotten on toshiba laptop
there are many bios passwords but most except 1 can be bypassed by a simple work around:
open your laptop exposing the mother board, look for a the CMOS/BIOS battery (the one in the picture). if you have more than one, remove both, then let it sit without the battery for at least 3 hours. (best if you do this overnight because results may vary depending on the model of your mobo)
after that, put the battery back in, put the laptop back together, and you are good to go.
good luck, hope you get this one running.
for more on toshiba laptop repair and TS tips, just click on the link below.
http://www.laptop-repair.info/toshiba_bios_password.html
-VooDoo MoX
2answers
How to break Toshiba SP4600 Laptop CMOS PASSWORD
reset the bios by unpluging to battery.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
