Hello
Press the eject button on your Toshiba DVD and insert the foreign disc. A window will pop up informing you that your DVD is a different region and ask you if you would like to convert to this region.
Click "Yes" when you are prompted to change the region. You will only have a certain number of opportunities to change your region. On the last try, your DVD will only play DVDs from the designated region.
Find out the Toshiba model number and use this to research a code that will break the region code assigned to your player. Each player make and model possesses a unique code to break the region code, so make sure you are using the correct one and follow it exactly as it is written.
