Clogged drain pump error is F21 error.----------
F21? is a Long Drain error.If the drain time exceeds 8 minutes this error code will be displayed.In addition, a ?SUDS? error may also be displayed.This may be an indication of a drain pump problem and/or clog in the drain line.You will need to check the following:
This will help.Thanks.Helpmech.
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
