If your asking which driver you would need for your CD Drive. The answer is you don't need a special driver for it. If it's not working then you could try cleaning the laser lens with a CD laser lens cleaning kit. If that doesn't work then you need to replace the CD drive.
Try this method it may work. If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
You can not format your hard drive using it's on software on the same hard drive. Because your notebook does not come with a DVD rom or CD rom what you need to do is to get yourself an external DVD rom which you connect to the computer with a USB cable. Then you use the disc of the operating system that you want to use on that Notebook. When you reboot the operating system disc will be recognized and on the screen you will be asked to press any key if you want to run the disc. So you will press and follow the instructions the rest will take you to formatting the disc and loading the operating system.
Hello mcrey, hi, your acer aspire has system board issues, this board needs replacement, the only advice worth giving is have this laptop serviced by a technician, for board replacement.
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
