The alarm automatically arms 30 seconds after you lock the doors
i looked around online and found info for you
The FACTORY ALARM DISARM WIRE IS
lt. green/orange '-'conn. 2, pin 9 @ the BCM.
The factory alarm disarm wire is
negative trigger thru a 473 ohm resistor.
MUST use relay. The BCM
(Body Control Module) is attached to
the left of the fusebox.
Connector 1 is a gray 26 pin plug,
and connector 2 is a gray 22 pin plug.
Once Located, splice into this wire with
a simular guage wire, add the specified resistor
and put it to a solid chassis ground.
This terminates the alarm functions entirely.
However, at this point, this car would be exceedingly
easy to steel, so I suggest you get an aftermarket
alarm system to protect it from here on in.
Take this info to your local
stereo/car alarm guy and have them
do this for you.
