Optics Logo
Posted on Sep 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 10" LX
Joe Lalumia aka TelescopeMan
Level 3:
  • Master 3,186 Answers
  • Posted on Sep 17, 2011
Master
Level 3:
Answers
3186
Questions
Helped
951633
Points
7111
You can return these to Meade for repair--
Here is the phone number:
http://www.meade.com/support/index.html
or you can send it to Dr. Clay in Arkansas for a Supercharge and he will repair it-
http://www.arksky.org/supercharge.htm
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
2answers
2answers
Good morning. Have a Whirpool Duet washer GHW9150PWO, 3yrs old, just started flashing "F" code with audible beeps at the spin cycle on the finish side. Checked owners manual under trouble...
well..sounds like perhaps the control board is having a fit..unplug it first, let it discharge(usually around 4 min) and then have a go at it again. Does this occur on all cycles?
What is the roman numeral for 60 and 90?
60 is 50 + 10, so it is lX
90 is 100 - 10, so it is XC
I have an older, let's say "classic" LX-90. My
You can try Three things:
1. Do you have fully charged batteries-- or a good power supply.
2. Sometimes the cable to the hand controller needs to be replaced
3. Execute a RESET on the hand controller and reload the firmware--
If these do not fix it, the hand controller is defective and must be replaced. You can find a used 497 controller for about $80 on AstroMart.com
and Meade can also sell you a new one.
1helpful
Meade lx-90 dec printed circuit board bad. where
Since you already disassembled the scope-- you can send the board to Ron Sampson and he should be able to repair it. He fixes main boards and hand controllers (including the screen and keyboard on the hand controller!)
If you post a message on the Yahoo LX90 group looking for Ron Sampson he will answer you. You can then email or phone him for instruction on how to send him the board.
ARE YOU SURE it's the board? It could be a bad keyboard or a bad cable on the hand controller. You should get another hand controller and cable and test it before you send it off. Can you borrow a hand controller and cable from anyone.... or from a local scope retailer?
I have a Meade LX 50 10'' sct that is having problems with the clock drive. The motor seems to be working, but the electronics seem to be going crazy. When you turn on the drive, a number of things might...
Check the autostar controller; you may have a stuck key. The telescope should run without the control - unplug it after it starts and see if the slewing halts. (don't plug it back in while powered) The other thing, would be a bad sensor on the motor.
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Vixen Telescope DD-1 Dual Motor Controller for RA and Declination
Vixen can repair your telescope-- and or the controller--
Contact OPT at this web site -- they are a Vixen dealer and can advise you about what to do--
http://www.optcorp.com/
Top Meade Optics Experts
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Meade Optic Expert? Answer questions, earn points and help others
