Televison & Video Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My SD3990 DVD plsyer will not power on - Televison & Video
macagunja Electronics
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 168 Answers
  • Posted on Sep 17, 2011
Expert
Level 2:
Night Owl:
Answers
168
Questions
Helped
21743
Points
414
Ensure that there is power in the socket and check that the power cable is firmly fixed to the socket. if power does not come on then switch off, remove the power cable from the socket then open the dvd player cover. plug in the power cable again and now measure if you are able to get power into the power supply unit. if power is reaching the psu then measure the output power which feeds 12v to the motherboard, if not present then concentrate on diadnosing the power supply unit as the power ic could be dead and requires replacement.
How do I restore Toshiba DVD player SD3990 back to original without password? Forgot password.
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared. "P CLr" appears on the
display for a moment.
3 Enter a new code as shown above to the left (Rating)
Good day! i have a ht965tzw model of lg hd dvd home theatre. recently, i cant seem to play most of my dvd plates anymore. evrytime i try to play a plate it displays disc error message.
I got the same problem. My Dvd plsyer is Pioneer. I found out that some dvd models 'choose' plates. it's lime they have code or something to be able to read before the player 'agrees' to play.
2answers
Hi -- my toshiba SD3990 model DVD player won't
Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
How do I reset my mp3 plsyer?
You need to make sure that you have at least 50MB of free space for the player to load the database. If you have at least that much space then it is likely that the firmware has gotten corruped.
First, connect your player and back up any important media items that are on it.
Next, download and run the firmware installer from the RCA website:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/5635
My cd plsyer is stuck wat can i do
Try unhooking the battery for 5 minutes
My Yamaha receiver stops working when using DVD plsyer
Is your BluRay connected via HDMI? and if so, are any other sources connected the same? if not, just for arguments sake, try hooling up the BluRay via component and digital coaxial or optical. Yamaha as well as all other AV receiver MFG have had big issues with HDMI processing. HDMI has been battling with the recording industry over HDCP and copyright issues on recording via HDMI. So, that's why HDMI has been so flaky. It's been thru versions 1.1,1.1a,1.2,1.2a,1.3a, and now 1.3b, which seems to work so far.... Anyway, sorry to stray off topic, however, HDMI has been a blessing and a curse for both professionals and consumers alike and has caused multiple strange issues with all products that use the technology. Hope this helps. Post a comment if you need further help. I've got lots of contacts for crazy issues!
Detected
Try another service pack on your windows XP or use Winamp ( Newest version ) To transfer music to your mp3 player.. hope it helps :)
2helpful
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
2answers
Eeee ..Need Help >.<
The songs might have a virus in it or they might be corrupted. Reformfat the sandisk by going into MY COMPUTER and then finding the devices icon and right click on it and click on FORMAT.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
