SOURCE: can i block a incoming call 4m a particular number
Download iMobileTool Incoming Calls Blocker 1.51 from the below link and block the number you want with this software
http://www.topshareware.com/free-call-blocker-nokia-5130/downloads/1.htm
SOURCE: Unwanted calls
You can't prevent anyone from calling or sending texts to your number, but you can easily set your Nokia 1112 to ignore the calls as follows:
Menu -> Settings -> Call Settings -> No. Screening -> Options -> Add
You can also retrieve the number to screen:
Menu -> Call Register -> Received Calls -> Options -> Add to scrn. list.
Calls from screened numbers will not ring on your phone, you will see the number on your screen with a dustbin symbol; messages from screened numbers will go silently to the screened messages folder.
I hope this helps.
Regards,
Rob
SOURCE: Block incoming unwanted calls
no your mobile does not support call black listing features. there are some softwares available. i think your phone is not built with symbian operating system. Check whether your mobile supports symbian os. there are more call blacklisting softwares for Symbian os built mobile phones. Else if your mobile is java compatible then try to find some call blacklisting java softwares from websites
SOURCE: I want to block unwanted calls
its have black list software for your probleam
if u use that software u can control them unknown numbers as u wish
SOURCE: hi i want to block
Greetings,
In order to block calls from a particular number you need to contact your service provider. You can dial 611 usually. They can put a block on that number for you, just let them know if you are getting harrassing calls, etc.
Thank you.
I want ot block a unwanted call numer please suggest solution for Nokia 5233
