I have a richo 2018d all in one copier machine. when I powered machine a error code genereted sc 541 what is the solutionI have a richo 2018d all in one copier machine. when I powered machine a error code genereted sc 541 what is the solution
AnonymousMar 28, 2014
canon 405 printer problum has cod E001 PLESE SOLVE PROBLUM SIRcanon 405 printer problum has cod E001 PLESE SOLVE PROBLUM SIR
You can't post conmments that contain an email address.
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Yellow/clear key
7
and Hold Red/Stop key, for 5 secconds.
If this works, turn machine off/on, the code should be reset. Alltho the code may come back, when the Copier attempts to print a page. If this is the case, you need your Fusing unit Repaired.
