Error 1102" printer says please install correct colour cartridge, I have done this and tried every suggested solution on this site many many times. without success.
Now I believe it's its a problem with the print counter that is set by the manufacturer. "HELP does anyone know how to reset the print counter.
Derek.
SOURCE: Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
SOURCE: lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
SOURCE: I have a Lexmark P4350, I put a new 33 color ink
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO).
The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
Please follow the steps given below:
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark below.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power on the AIO.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges and clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions).
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
SOURCE: Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
SOURCE: I keep getting error message
cartridge jammes and i have a clear piece of plastic like a small belt of somekind inside
Please refer to this article on the Lexmark website to fix the issue about 1102 Error Message on the Lexmark P4300 Series All-In-One.
