Question about Kyocera Mita FS-1920 Laser Printer
Everytime i turn it on, says: load mp tray. and does nothing but bipping. When I tray to print something, sometimes, print a bounch of pages with numbers. What can i do?
    New Friend:
  • 67 Answers
Go to menu paper handling- mp tray mode start from there.........disable or something long time but will fix
Posted on Oct 18, 2012
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Posted on Nov 12, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: " Load MP Tray Letter"
Pull down the MP tray and load paper into it.
Posted on Jan 06, 2009
Anonymous
SOURCE: Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Posted on Apr 30, 2009
versa093
  • 46 Answers
SOURCE: MP Tray
Wrong papaer size settings check the settings
Posted on Jun 11, 2009
Uptech MN
  • 104 Answers
SOURCE: Trying to print labels, but
MP is the tray in the front it looks like a door on the front. When you open it it turns into a tray for you to put the label paper on.
Posted on Nov 19, 2010
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
WHEN WE TRY TO PRINT SOMETHING USING THE PAPER TRAY, WE GET THE MESSAGE THAT WE NEED TO LOAD THE MP FEEDER. WE JUST REPLACED THE PAPER TRAY BECAUSE THERE WAS A PIECE THAT BROKE OUT INSIDE OF IT. THOUGHT...
Your print job is looking for something other than one of your tray(s) selected size and the MP tray is sett to the correct size by manual selection. Set MP to "Statement" size and insure the trya guides in the Tray 1 match the program's selected paper size.
Jul 16, 2010 | Dell M5200n Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Messege * load mp tray * but tray has plenty of
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
It says to load paper in the MP tray
Pull down the front cover where it says Brother, the manual feed input is behind that panel (above the main input tray)
Nov 19, 2008 | Office Equipment & Supplies
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Kyocera Mita FS-1920 Laser Printer Logo
931 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
