These are delivered with a power supply. If yours has failed, LIKELY there are other problems. I have repaired several supplies and can coach you through which parts to replace. Often the failure originates with a shorted MOSFET in one of the amplifier channels, usually the rearmost one. Getting parts for these is really hard as FullCompass is the Behringer parts distributor. The SPS1000 supply takes out about $25 of parts when they go. The hardest parts to replace are the IGBT transistors as the heat sinks are hard to remove to get the screws out of the transistors. All the repair parts are available using five different online sources.
Iv noticed fred you know a lot about this range of mixers i received one recently totally dead first thing was the common fault on the psu f1 fuse blown then i found r11 to be totally destroyed as far as i can tell both igbts are also blown are you saying that the problem is in the amplifier its self so i need to repair that aswell as the psu board?
