Computers & Internet Logo
Posted on Sep 19, 2011
Can you get data off of a flash drive that not working? Like send it to have it fixed
2helpful
2answers
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Kingston flash drive when sending files,data and media displays a dialog box >> like this WRITE PROTECTED-- help me pls...
it seems that the file or the system in your flash drive error, to fix this issue try to format your flash drive. To format the drive you can follow this way
right click on my computer icon in our desktop
click manage
click disk management (in a storage tab)
right click on your detected flash drive (could be in F)
click format
make a system as fat32
list on perform a quick format
Notes: it will erase all your data on your flash drive
2answers
Transcend Jf V30/ 32 gb flash drive. When saving data less than 4GB and after removal of flash drive most data are lost. What can I do ?
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
3answers
My usb is not being recognized when i put it in because either it is not updated or not working correctly? which one is it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
1helpful
Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
How do i download information from my desktop into a flashdrive
1. PLUG THE FLASH DRIVE IN USB PORT, RIGHT CLICK ON THE FILE U WANT TO SEND TO FLASH DRIVE AND SEND TO FLASH DRIVE.
2. COPY THE CONTENT U WANT TO SEND TO FLASH DRIVE, PLUG THE FLASH DRIVE IN USB, EXPLORE THE PC BY EXPLORER AND SLECT THE FLASH DRIVE, DUBBLE CLICK IT AND WHEN IT OPENS JUST PASTE THE DATA THERE.
7helpful
6answers
My flash drive is faulty and i want to retrieve my data
dont panic, try this data recovery program called asoftech data recovery.
http://www.asoftech.com/adr/
I used the program before, it helped me recover my files from pen drive. If it does not work, you may try quick format the pen drive and then use asoftech data recovery program to recover again your files.
23helpful
13answers
Data recovery from a broken usb flash drive ? model dane elec zmate pendrive 512mb
Does the flash drive been detected by computer? If not, you may try other usb port, or other computer and see whether the flash drive is detected. If still not, try to go to device manager and then assign a drive letter to the flash drive. After that, download a flash drive data recovery software, recommended asoftech data recovery, you can refer to this tutorial
How to recover files from usb drive
If still does not work, you may format it (use quick format) and then use asoftech data recovery to recover your files.
Here's a video tutorial I find very useful
May 03, 2008 • Cameras
2answers
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
