Question about Sharp Televison & Video
How to get rid of closed captioning - Sharp Televison & Video
  • Sharp Master
  • 736 Answers
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Posted on Sep 20, 2011
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
Anonymous
  • 137 Answers
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
How to turn off CC to get rid of that black box
Here's the link to the manual. CC instructions are on page 22.
http://books.jvc.com/Download/77833385/LCT0604-001B-A.pdf
Closed Caption
Use this function to display the Closed Captioning
text onscreen (when included in a bro a d c a s t ) .
P ress the ME N U b u t t o n
To CLOSED CAPTION
To operate
To select Caption, Text, or Off.
To CAPTION or TEXT
To select a caption or text channel
To FINISH
To save setting and exit
Dec 31, 2012 | JVC AV-20120 TV
Anyone know how to turn off closed caption
U have the tv original remote.Look for a button that said CC.Pushes that CC button a few times turn off all CC1,2,3.. to all off,will not have Closed Caption anymore.Or tries go into the tv nenu look for Close Captionning or Text 1,2,3 functions tun it all to of.Will get rid of Close Captionning.
Jun 13, 2011 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
There is a large black rectangle in the middle of the screen. It goes away for a second when I press the EXIT button on the remote and for about 4 seconds when I press the RECALL button on the remote. ...
This is a text box. This can be turned off under the closed captioning. There should be a cc button on your remote or the closed captioning features can be accessed from your television's menu. Turn closed captioning completely off to get rid of these text boxes.
Keep in mind that closed captioning can also come from your cable box or satellite receiver as well.
Sep 28, 2010 | Toshiba 32A33 32" TV
Why does close-caption appear on screen eac time I turn it on.
On your remote control find the CCD button and press it until you find the option to turn off the closed caption or select the closed caption option to use only when the sound is muted. If this does not eliminate the problem, you may have a switching problem in the control panel.Try turning off your television for a period of time and then turn it on and try resetting the control. If this fails you may want to contact customer service for technical help at 1-877-467-4289. Hope this helps you with your problem.
Apr 24, 2009 | Insignia LCDTV26 26 in. Television
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
Feb 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Can not get rid of closed caption from screen. Manual lost
Simply hit the cc button twice. Thank you and have a Happy Holiday
Dec 21, 2008 | Philips 20DV693R 20 in. TV/DVD Combo
Big Black box covers screen
On the remote control is a button called closed caption or CC.. Someone turned on the closed caption. Simply turn off the closed caption. That black box is called the text box. Good Luck
Apr 12, 2008 | Philips Magnavox 27MS343S 27" TV
Closed captions will not disappear
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
1,802 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
