You should never try to connect any cables when the devices are on. Always try to connect inputs or outputs after switching the devices off manually. Looks like the input port has gone bad. Try switching off the monitor, removing the plug and leaving it for 48 hours and retry. If you notice problems still, it is better to refer it to a qualified service technician.
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds.
That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
