Apple iPad 32 GB 3G Tablet PC Logo
Anonymous Posted on Sep 20, 2011
Son gave me ipad1 connected to 3g if i reboot/reset will i also have to reenter 3g data for it to work
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Nov 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
3544
Points
45
No, you will not need to re-enter any 3G data for it to work. You can freely reboot the device without losing any 3G settings.
I have an acer tablet that I have forgotten the password for. How can I get into my acer tablet
Step 1 Acer Iconia Tab B1-711 3G - Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. ...
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen
I forgot my unlock code for my old ipad1 haven't used in in months
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
How to an lock my tablet forgot passwort
Someone else asked the same question. I copied and pasted the answer to save it for myself. (This is _not_ my answer. I am quoting the technician who gave it, including her name).
Note: This ''should'' work regardless of manufacturer. It is an ''Andriod'' thing.
Andoid cell phone reset
Here are the steps to perform a hard reset in your device:
1. Switch off the device.
2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
4. When you see Android with triangle, then press together Volume Up + Volume Down.
5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
6. Choose option "Yes -- delete all user data" and accept with Power button.
7. Press Power button to select option "reboot system now".
Best Regards,
Katy
Motorola Support
I can not connect wirelessly
I have had this problem before and I had to go under WiFi settings and forget my WiFi. I let it scan again for service and reentered my WiFi network information. This worked for me most of the time. However, it could be your WiFi itself. Can you connect anything else to your WiFi?
Iam not able to enter into the systems... the tablet shows always the words ' IRULU connecting my world' in continue... I have done a reset but it is teh same result.. What can I do..
Hold Power button with volume up for 5 second try to reboot if that does not work try to remove the battery for 5 minutes and put back in , then reboot ( turn it on ) !
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
7helpful
Samsung tablet isn't connecting to 3g network but will connect to WiFi
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
1helpful
2answers
Won't connect to 3g or wifi
Enable data connectivity on settings. To activate 3G, you must add a valid access point (APN)
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
