SOURCE: how to rotor removal on a coleman 5000 with
This is going to sound crazy but....with the bolt hole straight up fill the inside of the rotor shaft where the long mounting bolt passes through with oil. There should be a threaded area right at the bolt hole. Get a bolt to match the tread and then wrap the bolt with teflon pipe tape. Place a rag on the back of the engine and then start rotating the bolt. When it separates you will hear a BANG and the oil will drain onto the back of the motor where hopefully you put the rag. It really does get your attention when it pops loose.
Kelly
