Question about Nokia 3110 Cellular Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
    New Friend:
    Problem Solver:
  • 5 Answers
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Posted on Sep 21, 2011
6ya staff
SOURCE:
Unlock security code for nokia 206
The default Nokia security code is 12345 unless it was changed.
Mar 10, 2013 | Cell Phones
Forget my security code nokia asha 305
Dear:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 23, 2012 | Nokia Asha 305 Unlocked DualbandGSM Cell...
How can i get my security code I forget it?model:1209 type:rh-105 code:0560687 imei;355224/03/913886/9
Hello. . I forget My nokia 1209 security code.. My mobile type RH-105 .. Code 0574218... Imei 356027/03/967628/6.. Plz give me unlock code
Oct 01, 2012 | Nokia 1209 Cell Phone
How can unlock nokia 101 security code
Hi
I have Nokia 101 and i forgot my security code
my IMEI no. 351932/05/243156/5
351932/05/243157/3
Plz give me the mastercode so that i can open my phone lock
my mail id; manishpr003@gmail.com, plz reply me asap.
Aug 14, 2012 | Cell Phones
I changed my my nokia x1-01 security code and forgot:(
i have forget my password in nokia x1-01 plz help me
Jan 04, 2012 | Cell Phones
How to unlock nokia 1202-2 SECURITY CODE
I forgot my nokia 1202 security code,which imei no is 355240/03/749662/0
Nov 22, 2010 | Nokia Cell Phones
I forget my security code therefore i cant restore my nokia 1280 phone plz help
I need an unlock code my imei is354338048273938 model 1280
Oct 19, 2010 | Cell Phones
I forgot my security code for my nokia 1110(i) my imei is-356268/01/510003/8...thanks
IMEI: 356268015100038Mastercode: 6446016173
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
Jun 01, 2009 | Nokia 1110 Cellular Phone
6233 security code unlocker
i have forget PW to unlock phone lock. My IMEI is 359727006727643.
Jun 12, 2008 | Nokia 6233 Cellular Phone
Nokia 3110 Cellular Phone Logo
618 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
