It all depends on how your set up is. If you are connected through USB, you will need to download the twain driver from the Kyocera website. Then you can utilize any scanning program that you wish to collect the document image.
If you are connected through ethernet, it's a little more complicated. The first choice you need to decide is what you want done with the document image after it has been acquired. There are three main choices: Upload to FTP server, Send to a folder on a computer through SMB, or email.
All three of these options are obtained through the Kyocera Command Center software installed on the printer. Point your browser to http://192.168.2.10/ and you can login. If it asks for password, the unit ships with password "admin00", so that should get you in unless someone changed it.
You can adjust the settings through this screen. Head over to the "scan" tab, and you can put in the information for whichever way you want it. If you decide on Email, you will notice at the bottom of the page a link to set up the SMTP options for sending the emails.
Another note with email: you will need to set up a DNS server in the TCP/IP section under "Basic" settings. If you don't have a DNS server on your network, you can utilize universal ones. I recommend using Google's DNS servers (8.8.8.8 & 8.8.4.4)
SOURCE: hp psc 950 from scanner to pc save
I was having the same problem when I pressed the "Scanner" and then "PC Save" buttons. But I found that if you have the printer software installed on your PC, you can double-click on the printer icon that should be on your desktop, and a window will come up where you can scan, copy & view images, etc. Hope that helps.
SOURCE: scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
SOURCE: Cannot send faxes; scanner and printer ok but fax
follow the link to solve the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669473&lc=en&dlc=en&cc=us&lang=en&product=441125
SOURCE: HP c4280 All in one printer, scanner, copier.
I d not have the alignment page for the c4280 all in one, therefore,
I cannot get the printer to print one for the new cartridges. HELP
How can I get the alignment page off he computer & scan it so I can get myprinter up and running.
