Hello Leonard,
You can just reset your wireless router to restore factory settings. If you reset it, your network name will be back to DLINK and you won't need any password. To reset it, look for the reset button usually found at the back of routers. It is a small button inside a small hole, so you will need a pin to press and hold it for about 10 seconds.
Thanks for using Fixya!
Don't forget to rate.
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if
you can log into the router. Some routers mask the wireless network
password, so while you cannot recover it, you can enter and save a new
password.
If you cannot log into your router because you have
forgotten the router password or your network has been hijacked, please
refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or
forgotten password from a router or access point; you will need to
reset the device to factory defaults. However, once the device is reset
to factory defaults, you can use the default username ("admin") and
password (either "password" or "1234" depending on your router) to
reconfigure your router settings.
NOTE: Restoring factory defaults
on a device will erase any customizations you have made. You will lose
any configurations saved to the device!
See the following articles for more information:
