Question about HP Office Equipment & Supplies
Printer is displaying the following message; 10. 1000 supply memory error
    Genius:
  • 1,089 Answers
There is a chip on the toner cartridge that feeds info to the printer regarding the status of the cartridge. Either the chip is bad or the cartridge was replaced with the chip missing.. Try reseating the cartridge and then power cycle the printer. If the error persists, replace the cartridge
Posted on Sep 23, 2011
6ya staff
SOURCE:
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
What is 10,1000 supply memory error with hp
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge.
Jul 21, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
10.0000 supply memory error (Problem
This is a problem with the toner cartridge, replace the toner and try an nvram:
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
May 21, 2010 | HP LaserJet M1522n MultiFunction Printer
I have replaced the printer cartridge (x3) and I am getting a error code 10.10.00 with every one of them on the printer. I have run through the cold start functions and nothing. Any suggestions?
yy
Action
Jan 26, 2010 | HP LaserJet 5550DN Printer
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Open Questions:
511 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
