Question about Ricoh Aficio CL2000N Laser Printer
I just replaced the color pcu on my Ricoh Aficio CL2000N because of the message that was showing up. I thought that would fix a problem I'm having with wrinkled paper as it comes through the machine and also toner on left 1/3 of the page that prints out is not sealed to the page. It's still powder and easily rubs off. Any ideas of what this might be?
6ya staff
SOURCE:
lolita
Rona Heredia
  • 385 Answers
SOURCE: Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Posted on May 12, 2007
Anonymous
SOURCE: My printer's nuts!
you need to replace the black cpu, if you go to their website it will tell you how to replace it step by step
Posted on Oct 19, 2007
Anonymous
SOURCE: Ricoh Printer Setup & Support Call 1-8O5-225-669O We are 24 Hour Available Call For Help//,
Go to the following link. At least this is where I found the latest driver for Mac OSX 10.5+
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/c30e/c30een.htm
Posted on Nov 29, 2008
docusultant
  • 58 Answers
SOURCE: Ricoh Aficio CL2000N
You may have to replace the transfer belt or the drum. I would start with the drum first
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
Everett Lin
  • 990 Answers
SOURCE: Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
Posted on Sep 18, 2009
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh Afiicio CL2000 Color register error.
You can try to reseat the color PCU, but you may have to replace it. Also, make sure all of your color toners are seated properly.
Jun 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Thin lines along left side of Ricoh CL2000N laser printer
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Mar 02, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
Sep 02, 2008 | Ricoh Aficio CL2000N Laser Printer
White streaks in print outs
Check transfer roller, or change black cartidge, if it only happens to the black then there is something wrong with that part of the process.
Oct 22, 2007 | Ricoh Aficio CL2000N Laser Printer
My printer's nuts!
Sep 05, 2007 | Ricoh Aficio CL2000N Laser Printer
May 12, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
196 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
