You have to be specific about the engine turning over
That is done by the starter circuit
Some people call that cranking
Some people also say it won't crank, when they mean
it does crank, but won't start
Not turn over the engine -----
Old & Weak Battery
Dirty Battery Cables
Worn out Starter Solenoid -- you can buy & replace
without getting the entire starter
A bad Starter
I should clarify, when I say a few turns of the key, the truck sounds like it is trying to turn over. It is similar to how a car will eventually start in sub zero weather. You turn the key, the lights turn on and the truck is trying to start but it just takes some time. Not how you want to start your day, that little panic in the chest. I will start with a new battery and see how it goes from there.
