How do I fix error code sc 548?
SC548: Fusing unit installation error -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
Possible causes:
Fusing unit is not installed
Poor fusing unit connection
Check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of position. SC 548 usually happens when a paper jam occurs and user does not properly fit the fuser back in place
The fuser may also not be fiitted properly due to some foreign object in between fusing belt and the sensor
From the panel, enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off, wait 30 seconds, the turn it back on.
To enter SP mode, press the yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button. from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Your machine should now be working.
Hope this helps.
