and if you require click on this
link to download the service manual for your LG WM2688H Washer. Hope this
helps...please post back for further assistance.
You may have a broken motor sensor and it will need to be replaced. You will need to call a qualified service technician who can work on LG's to help you with that.
Good luck
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
LE indicates the motor is locked. Check the 3 pin connector at the motor and check the 4 pin connector at the main control if they look good ( no corrosion and fit tight) replace the Hall Sensor. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Sensor on drive motor needs to be replaced, this RPS sensor communicates to main computer how fast machine is turning, if it fails, the ie error will show, when replacing sensor, inspect wire going to it to make sure it hasn't broken, it is a yellow, blue, red harness.
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
