Expert
- Posted on Sep 23, 2011
Re: Need user manual and software for a HP ScanJet 4p...
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF)
Tips for Using
Step 1 - Load the Paper
Step 2 - Scan the Document
To Scan a Single Page
Tips for Using
Remove any paper from the copyboard glass before using the ADF.
Straighten any curls or wrinkles from
documents before putting them on the document tray. If this is not
possible, do not scan these documents using the ADF. Instead, use the
copyboard glass or make a photocopy of the documents and scan the
photocopies.
Remove staples, paper clips, and any other materials from documents.
Avoid documents with tears, perforations, or punch holes.
Do not use the ADF to scan sheets of uncommon paper or other media, such as the following:
transparencies
gummed-backed paper
magazine pages
lightweight ("onionskin") carbons
For paper smaller than 5 inches (127 mm)
by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches
(216 mm), use the scanner glass instead of the ADF. Paper smaller than
the minimum size may cause a paper jam.
For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Besides the instructions below, quick
reference decals on the input tray and access hatch show the order of
steps for paper loading.
Turn on the scanner.
Ensure the scanner's scanner glass is free of paper.
Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
Push the paper stack up against the
green document guide and slide it right against the green registration
stop, which is in the middle of the paper load window.
Turn the green paper load lever 45
degrees into the closed position. This will secure the paper stack.
Refer to decal number 3 on the ADF access hatch. The ADF is now loaded
and ready for scanning.
The ADF works with many software packages
that are compatible with the HP ScanJet color scanners. To scan a
document, refer to the user's manual of the software package being used.
To scan a single page while the ADF is installed on the scanner, do the following.
Remove any pages from the ADF input tray.
Raise the ADF.
Place the page on the scanner's copyboard glass.
Lower the ADF all the way and do the scan.
- LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
- LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
