My NVM on PDT6800 has been erased and I can not load a new program. I always get status 0020. How and where can I load the software to be able to get the main menu back again? Thanks,
C-0020 is a code f the circuit board that is located in the middle section that you pull, is not talkking to the control board in the back of the machine, or has software program issue and needs to be re-flashed.
You need Manufacture provided Software Devepment Kit. I cannot attach a file here so let me know if you still need this. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Pre-Installed Maps: Set up of the Easy Street Navigation System is simple because there's no software to download. Maps are pre-loaded and ready to go. Map data covers the US, including Alaska and Hawaii, Canada and Puerto Rico.
SANYO NVM-4370 Map Update DVD North America 2009-2010: Get accurate directions to wherever you travel including new roads, new sub-divisions, and current addresses. New and expanded coverage in over 159 cities, counties and metropolitan areas across the continental United States and Canada including Alaska, Hawaii, Puerto Rico and the U.S. Virgin Islands. You can confidently drive through unfamiliar or recently changed areas. This latest edition features over 6.18 million miles of navigable roads and an updated list of over 7.57 million Points of Interest to help you find the way to where you want to go quickly and efficiently.
CAUTION - I called SANYO's customer service @ (800) 421-5013 to ask
about map upgrades, getting maps for other countries for the SANYO NVM
-4370. The answer: THERE IS NO CURRENT ABILITY TO UPGRADE EITHER
SOFTWARE OR MAPS!!
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
That has to be done with the diagnostics software. That has to be on a laptop computer to access the NVM. Once connected to the machine from the computer, you can reset the NVM and all other settings back to default. You can try shorting the NVM battery to reset the memory but I would NOT recommend that move .
