Question about Sony BRAVIA KDL-46W3000 Television
Thin green lines running down the center - Sony BRAVIA KDL-46W3000 Television
  • 11,361 Answers
It can be bad T-CON or bad LCD panel. You can try reseating the ribbon cables between the T-CON and the LCD panel (delicate works) to see if it fixed the problem.
Read more about T-CON/LCD panel troubleshooting here:'
T-CON/LCD PANEL troubleshooting: http://www.mediafire.com/?zzjygannjty
Multi lines next to each other, or spacing apart?
LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Sep 24, 2011
6ya staff
SOURCE:
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
What might be the cause of a thin green vertical line running down the center of screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
How do I get rid of green line?
your problem is a faulty T CON BOARD.
Part number TCON BOARD 6870C-0060F
hope 2 help
www.bostonrecycling.net
Jun 30, 2012 | Panasonic TC-32LX70 Television
Thin green line running down screen on my dell latitude d630
you can try re-seating the LCD cable, see if that makes any difference.
Press Power + D at boot and see if the Green line appears in the 4 solid color screens during the BIST test, if it does, replace the LCD
Oct 04, 2010 | Dell Latitude D630 Notebook
A thin green line running through screen
1.The LVDS or T-Conn panel is defect and must be replaced or 2, the panel must be replaced complete.
Aug 10, 2009 | Televison & Video
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green line
ahhh..the old green line. early warning that your LCD screen is tanking. Will eventually spread(like a crack in your windshield) until there's more of a band. Comes from a defect in the screen material. Suggest you get a warranty extension or a service call set up. Not a big deal, but does require correct parts.
Feb 03, 2008 | Acer Aspire 3623WXMi Notebook
Sony BRAVIA KDL-46W3000 Television Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
